Results 1 to 9 of 9
Thread: MK63 VS S/Z fronts
    Jul 2010
    Litchfield Park ARIDzona
    382
    MK63 VS S/Z fronts
    anyone know if these have the same bolt spacing? i have some front Z32/S14/15 brakes, and im thinking about buying a set of brackets that are listed for MK63's, but im not 100% sure they will work. any ideas?
    Jun 2012
    socal
    130
    Re: MK63 VS S/Z fronts
    Will not work. Buy the bracket for the R32 upgrade. The spacing is the same as your Z32/S's.
    Jul 2010
    382
    figures LOL, Thx!
    Jun 2012
    socal
    130
    I have a set of 4 piston front calipers that will bolt onto your stock front strut, use your stock caliper and not require any spacers or adapters. It will also fit under a 14" rim if you are still running something that small. I can mail FPO/AP no problem.
    Mar 2012
    The D Michigan
    182
    Can you send pics to me? If Wook doesnt want?
    I'm looking into purchasing Z32 TT front calipers they are Aluminum 280mmX30mm...
    Are these the same as R32 type M
    Rubber-Soul.net caliper bracket
    ? caliper bracket for Skyline R32 Type M (steel)
    \ 31,500 list price (\ 30,000) \ 25,200 deals (\ 24,000)
    ? caliper is also available for turbo Silvia, S15 S14 except for type M to Skyline. (For the Fairlady Z32 and R33 are not allowed.)
    Trying to confirm Want to purchase the bracket from Rubber-Soul but website says z32 will not work (wondering if they meant Z32 NA)
    Jose
    Jun 2012
    socal
    130
    Z32 on a stock KGC10 front strut will not work. The caliper and rotor are too large and conflict with the steering. Check out: viewtopic.php?f=12&t=19003 for pics. If you upgrade the front struts to newer skyline assemblies then no bracket is needed to run S13/14/15 or Z32 or R32/33/34 brakes. See my brake/suspension thread at: viewtopic.php?f=7&t=19655. There is a pic of my fronts with the modified struts and Z32 fronts.
    The older 4 piston calipers I have work with the stock rotor and stock front strut.
    Mar 2012
    The D Michigan
    182
    JNCR,
    Thanks that clears things up for me. I thought with the bracket http://www.rubber-soul.net/p-brake.htm sales its possible to run Z32.
    Had a good Source for the Z32 calipers for cheap looks like I'll pass.
    Jose
    Jun 2012
    socal
    130
    The link provided states the brackets will not work for R33 or Z32 brakes. Can you read Japanese?
    Mar 2012
    The D Michigan
    182
    Thanks, for the help...
  1. C10 with MK63 calipers - min wheel size?
    By ericbauer in forum Datsun/Nissan Garage
    Last Post: 03-26-2012, 06:06 AM
  2. IMPUL Hoshino 15X7+2(Rears)15X6.5+18(Fronts) 4X114.3
    By Scoobyjoe in forum Wheels Swap Meet
    Last Post: 07-08-2011, 06:37 AM
  3. Replies: 4
    Last Post: 12-31-2010, 05:49 AM
