Results 1 to 7 of 7
Thread: 280ZX Differential
    Aug 2012
    27
    280ZX Differential
    Does the 280ZX turbo with manual trans all have a limited slip differential? I have never been able to find a straight answer on this.
    Dec 2009
    Las Vegas
    70
    Re: 280ZX Differential
    No.
    Aug 2012
    27
    Ok, thanks.
    Is there any way to tell if the Z has one short of driving it?
    Or did they not come with one? I would find it hard to believe if this were the case but I guess its possible. These have a R200 differential right?
    Dec 2009
    Las Vegas
    70
    no 280ZX ever came with an LSD from the factory. not sure how you got "possible" from "no"
    they all came with open R200s
    New South Wales, Australia
    692
    Easiest way to check is this.
    Put car in neutral.
    Jack up 1 rear wheel off the ground.
    Turn the wheel.
    1, If it spins you have an open diff.
    2, If it locks you have an LSD
    3, If it gets a bit harder but still spins it's probably a worn out LSD.
    To check, jack both rear wheels off the ground and turn 1 wheel.
    If both wheels turn the same way it's an LSD.
    If the other wheel turns opposite to the way you are turning the wheel it's an open diff.
    Simple. 8)
    Jun 2012
    socal
    130
    Z31 turbos have the LSDs. CLSD is better than VLSD.
    Dec 2009
    Las Vegas
    70
    only 4/87+ Z31T has CLSD
    misinformation sucks :|
    '88 SS had VLSD
    shimmed VLSD can be rad, I had one and loved it till my hybrid axle broke, now I'm rocking a welded and it's awesome, too.
  1. Welded differential
    By Matches in forum Toyota Garage
    Last Post: 02-19-2015, 03:29 PM
  2. WTS: 198? 4.1 to 1 GSL-SE Limited Slip Differential, Denver.
    By ColoradoKP in forum Mazda Swap Meet
    Last Post: 10-01-2013, 04:39 PM
  3. R200 3.54 Differential in great condition
    By Kennymonster in forum Datsun/Nissan Swap Meet
    Last Post: 07-16-2013, 04:16 AM
  4. FS: R180 Nissan LSD Differential & Shafts from R30
    By Heatw in forum Datsun/Nissan Swap Meet
    Last Post: 05-31-2013, 05:34 PM
  5. Ex A175 Lancer Differential SWAP
    By torana68 in forum Mitsubishi Swap Meet
    Last Post: 05-14-2011, 06:55 AM
