Results 1 to 8 of 8
Thread: Rear DIY coilovers
    Jul 2012
    438
    Rear DIY coilovers
    Here is an interesting idea that I will probably be doing. Its off of another site, but It will work for us too.
    http://community.ratsun.net/topic/30....%20coilovers/
    Hope someone can use this info
    I will probably put these on a custom 4 linked axle. I think these will go well with a set of shortened and adjustable AE86 struts.
    Jul 2012
    438
    Re: Rear DIY coilovers
    Sep 2010
    Magna, UT
    689
    The link for ratsun didnt work....
    Jul 2012
    438
    http://community.ratsun.net/topic/30153 ... 0coilovers
    I think this link will work. I'm not the best with this linking stuff. Just trying to share some info i found ops:
    not sure how to edit my original post.
    Feb 2009
    Hoquiam, WA
    712
    That seems a bit sketchy. You'd really have to beef up the shock mounts, they aren't made to support the weight of the car. Idk if I'd trust this to be honest.
    Edit: idk if 510s have struts out back or shock/spring setups, so I may be wrong. I'd still be careful running a shock as a strut in either case.
    Jul 2012
    438
    very true. Reinforcement will definitely be needed. I own a TE31, so in my case I would probably be putting a 4 link + watts link in ditching the leaf springs.
    Feb 2012
    20
    Well techno toy tunning makes a rear coilover shock set-up for the AE86 & for the KP61 starlet & thet both mount in the stock location with out any reenforcement needed! So the set-up in the Ratsun forum should work in the AE86, TE72 or a KP61..
    http://technotoytuning.com/toyota/ae86/ ... 86-corolla
    Quote Originally Posted by shane_lxi
    Feb 2009
    Hoquiam, WA
    712
    Hay man, go for it! I'm not an expert by any means, just throwing my 2 in, and I may very well be wrong
  1. S13 coilovers into DR30 - kit
    By clubracer in forum Datsun/Nissan Garage
    Last Post: 02-24-2015, 01:18 AM
  2. WTB: mx73 coilovers
    By JZX in forum Toyota Swap Meet
    Last Post: 05-01-2014, 04:07 AM
  3. Rear Coilovers:Need skinny 2.5" O.D..
    Last Post: 04-23-2012, 04:09 PM
  4. mx63 cressida coilovers + rear suspension+gx61 headlights
    By toji004 in forum Toyota Swap Meet
    Last Post: 12-27-2011, 10:09 PM
  5. Replies: 1
    Last Post: 03-06-2011, 05:41 AM
