Results 1 to 9 of 9
Thread: 4M Emissions Delete and Carb Options
    Jun 2011
    Murray, UT
    153
    I have a 4M in my 73 Corona MarkII and it runs well with the stock carb. I would like to clean things up a bit and simplify the engine bay. I have found a little info on JNC on removing the emissions vacuum tubes and the "evap. emissions control device" box. What can be disconnected entirely and what needs to be capped/rerouted etc? I have heard that the dist. advance and brake booster is all that needs to remain. I don't need to pass any emissions standards anymore. My plan was to remove one at a time to make sure that it did not effect the car but any other info would be appreciated. Thanks!
    Also, just curious, what carb settups have been done successfully to a 4M? I have a Weber that I may put in at one point but has anyone heard of adapting side drafts maybe? The engine has plenty of life left in it so I don't have a swap planned for the near future.
    Jun 2012
    West coast Canada
    79
    Re: 4M Emissions Delete and Carb Options
    I have a 1979 4M emissions manual for U.S. and Canada that's yours for the price of postage if you want it.
    Oct 2011
    Alberta
    171
    Quote Originally Posted by palatine
    That won't be the same emissions system, there are a few different pieces. However, I might be able to use it for my Cressida. PM sent
    Jun 2011
    Murray, UT
    153
    ^^ I was a little worried about that too. Lots of things changed in those 6 years. Hope you can use it. Thanks!
    Oct 2011
    Alberta
    171
    Yeah, just for an example, my system doesn't even have that box. I'm even somewhat worried that the 790 book won't be exactly right for my 78 since I believe all 79s were fuel injected and I'm running a carb
    Dec 2010
    Houston, TX
    191
    I'm assuming you saw what jzcelica did to mine in his old thread, right? viewtopic.php?f=9&t=13570
    Jun 2011
    Murray, UT
    153
    Yep, I referenced that. Thought about asking him directly too. I know he removed it but just wanted to make sure there weren't complications since I will be keeping the stock carb for at least a little bit.
    Oct 2011
    Alberta
    171
    I think you should be fine so long as you, of course, plug the vacuum ports. I'm pretty sure he threw a weber on at the same time as his de-smog work.
    Jun 2012
    West coast Canada
    79
    Quote Originally Posted by stefman454
    True, that. Well, it's still yours if you like, and toydatto: I've also got a '76 all models emissions manual that's the same offer to you if you like. A few years closer anyway. I've got to thin down my parts boxes and I'd rather these get to someone who needs them on JNC. PM if interested.
  1. Honda ET2 Dual carb emissions delete?
    By ColoradoKP in forum Honda Garage
    Last Post: 11-29-2013, 12:28 AM
  2. TE72 - won't passw emissions..
    By benny_b in forum Toyota Garage
    Last Post: 06-11-2012, 05:21 AM
  3. Toyota Emissions and Vacuum Decals
    By pholife1 in forum Toyota Swap Meet
    Last Post: 02-22-2012, 03:53 AM
  4. WTB: 4m or 5m carb'ed intake manifold and carb!!!!!!!!!
    By just_a_supra in forum Toyota Swap Meet
    Last Post: 01-12-2012, 01:50 PM
  5. DCOE Carb help? - Carb bogging down at acceleration
    By avianman in forum General Discussion, JNC News & FAQ
    Last Post: 04-09-2011, 06:53 PM
