Results 1 to 10 of 11
Thread: NA to MA flywheel differences
    Jul 2012
    11
    Hi, I'm currently in the process of putting my 76 121 back to its former glory which included a turbo MA 2.0l. Its been in storage for the past 10 years and some where along the line I've lost the flywheel, being a bit of a budget resto and wanting a lighter flywheel(have a 1ton pressure plate) do any of the NA, VC or MA flywheels interchange?..
    cheers, Thomas
    Mar 2010
    Ballarat
    197
    Re: NA to MA flywheel differences
    Direct changeover BUT 1600 has a smaller clutch - eg clutch plate diameter 200mm(7.87") vs 215mm(8.5")
    Jul 2012
    11
    is it possible to machine the NA to fit an MA pressure plate?
    Apr 2010
    belgium
    24
    Why not use an NA clutch then?
    When i was building my MA, i also considered using an NA flywheel, but i can't remember why i didn't do it in the end. I thought the NA was smaller, so the starter wouldn't catch the ring gear, but philip says it's a direct changeover so I'm not sure now..
    Jul 2012
    11
    I'm not sure if the smaller NA clutch would handle the power.. its to go behind a turbo MA that spins the wheels into fourth, plus I already have a 1 ton clutch for an MA/VC.. just want it to rev faster without going for a billet flywheel..
    This is what its to go in..
    Mar 2010
    Ballarat
    197
    Nice! :tu:
    Have you checked the maximum outer diameter dimension
    of the NA flywheel. You might find the MA clutch assembly
    will fit it!
    Jul 2012
    11
    Nah, I cant seem to find anything around here for the F/MA at all, plus I don't even have a standard flywheel, is there a chance that an FE flywheel would fit or are they just completely different ?..
    Mar 2010
    Ballarat
    197
    What part of the world are you in?
    Jul 2012
    11
    Christchurch (NZ)
    Mar 2010
    Ballarat
    197
    Just checked Trade-me. There is a place in
    Palmerston North with a fairly good range
    of correctly aged Mazda's - have you tried them?
    If you get/are totally stuck, I can get you one,
    but the freight for a flywheel from Oz to NZ is going to be
    astronomical!!!!!! :shock:
  1. WTB: 18R Flywheel
    By fressssssh in forum Toyota Swap Meet
    Last Post: 04-24-2013, 09:34 PM
  2. 3tc flywheel
    By oldskoolte86 in forum Toyota Swap Meet
    Last Post: 05-13-2012, 05:44 PM
  3. Differences between 2T-C and T engines?
    By in forum Toyota Garage
    Last Post: 05-29-2011, 12:43 AM
  4. WTS:2TG 12.5lb flywheel 200$ TENN
    By rubhamusan in forum Toyota Swap Meet
    Last Post: 03-02-2011, 07:03 PM
  5. 4G63T Differences between Auto and Manual ??
    By xSnoWx in forum Mitsubishi Garage
    Last Post: 01-30-2010, 08:22 PM
