Results 1 to 7 of 7
Thread: safety of using an acid on an aluminum engine
    Jul 2012
    ON, Canada
    5
    I have been attempting to unseize the pistons in my 1971 Honda an600. I have tried many methods with no avail, such as wd-40, motor oil and diesel fuel to try to coax the pistons into moving. I have been tapping the top of the exposed pistons with a block a wood and a hammer and no movement. I heard that using phosphoric acid could break up the material between the pistons and the cylinder wall. However I am afraid that the acid could damage the engine. Any thoughts on this?
    Jan 2012
    Qld
    94
    Re: safety of using an acid on an aluminum engine
    you might have to heat the block up and cool the piston?
    Jul 2012
    ON, Canada
    5
    Quote Originally Posted by uras1
    Thank you.
    good idea but since this is my first big car project you might need to be a little more specific, I don't know allot about cars but I'm a quick learner. How do you suggest heating/cooling, heating could be done with a blowtorch but how would I cool it?
    please correct me if I'm thinking in the wrong direction.
    Jul 2012
    ON, Canada
    5
    Problem solved.
    I used a bigger hammer. 10 pound sledgehammer did the trick.
    Apr 2012
    Seattle
    22
    When all else fails, bring out the hammer. In the future you can try using PB Blaster. That stuff works miracles on rusted/stuck engine parts and nuts and bolts. Soak it and let it sit for a few hours, soak more, try to move it, soak more, repeat until it's free. Worked for me a few engines including a particularly bad 1964 Buick Nailhead motor.
    Mar 2010
    New Jersey
    24
    Automatic transmission fluid works well too. High in detergents and works well to get in all of the tight spots. Worked for me a few weeks ago to free up an engine that seized from running out if oil.
    Apr 2010
    socal
    31
    brake fluid works very well also. just let it soak for atlleast a day
  1. FS Z32/R32 Aluminum rear calipers $70
    By ericbauer in forum Datsun/Nissan Swap Meet
    Last Post: 08-28-2015, 02:15 PM
  2. Vintage Appliance aluminum wheels DIA-MAG UNI LUG $300
    By Aceofspades in forum Wheels Swap Meet
    Last Post: 06-05-2015, 05:06 AM
  3. Cusco Safety 21 roll cage fitment issue in 1973 Datsun 240Z
    By ericbauer in forum General Discussion, JNC News & FAQ
    Last Post: 08-22-2011, 02:53 PM
  4. Tips on Shining Up Aluminum
    By SCT in forum Resto Tips, Wheels & Other Goodies
    Last Post: 05-19-2011, 06:46 AM
  5. 91' Z32 4-pot calipers..Aluminum,very nice upgrade!
    By superboosted in forum Datsun/Nissan Swap Meet
    Last Post: 02-10-2010, 06:26 AM
