Results 1 to 3 of 3
Thread: Head gasket set for 4M-MX29
    Jul 2012
    Orange County, CA
    116
    Hey guys, I guess I got a little eager trying to get this 4M done, its gets back from the machine shop at the end of the week, only I forgot to check to see if a head set was available. Coming across everything, I can't find anything at all. I did find a fel-pro part number HS8832B-1, which fits the 76, 77, 78, only the front by the timing cover looks wrong, so I didn't want to chance it. Anybody have an idea where I might be able to get the head set for my 73' mark II wagon? Thanks!
    Aug 2009
    Spokane, WA
    280
    Re: Head gasket set for 4M-MX29
    might check with rockauto.com. They have most everything to keep the old MKIIs going mechanically. It might not be listed under Mark II. Maybe Cressida or other cars with 4Ms. I found this one http://www.rockauto.com/dbphp/x,carc...ad_Gasket.html I hope it helps
    Jul 2012
    Orange County, CA
    116
    Thanks! Checked it out, they actually have a lot of items I need, except the head Gasket, I came across that one too, but the timing cover pattern is different where the bolt lines up. But other than that I'm ordering a ton of other items :mrgreen: ! Thanks you!
  1. rwd 4g32b head vs a 4g37 head, also turbocharging the lancer
    Last Post: 07-06-2013, 03:26 PM
  2. Cylinder Head Gasket
    By Oli in forum Datsun/Nissan Swap Meet
    Last Post: 03-27-2011, 12:03 PM
  3. Can I put a 2tc head gasket onto a 2tg?
    Last Post: 05-25-2010, 12:54 AM
  4. Will a 4M head gasket work on a 2M?
    By te37jake in forum Toyota Garage
    Last Post: 05-24-2010, 10:11 PM
  5. Copper spray for copper head gasket.
    By spiff in forum Resto Tips, Wheels & Other Goodies
    Last Post: 05-24-2010, 06:53 PM
