Announcement
Collapse
No announcement yet.
Mazda VC or MA
Collapse
X
  • Filter
  • Time
  • Show
Clear All
new posts
  • Hiroshima
    started a topic Mazda VC or MA
    Mazda VC or MA
    Hi guys; I'm new to this forum.
    I am restoring a '75 Capella and need to start engine work soon. It's imperative to me that the car stays era correct so engine swaps are out of the question.
    I messed around with a VC many years ago when I was still an apprentice: high compression 81mm F6 pistons specially pocketed and converted to free floating, lightened and balanced bottom end, milled 1mm off head, 2mm off block, 1 link of timing chain removed, bigger ports, high lift cam, twin 40mm Webers etc.
    Bar blowing a few head gaskets(this was sorted out eventually) it went very well.
    I have no experience with the MA as they're very scarce over here, but I can get my hands on one now;
    What are the performance advantages of the MA over the VC?
    Do they still rev well enough? I know the stroke is 10mm longer
    Is it worth the effort for the extra 200cc?
    Thanks
    Mazda nut
    South Africa
  • Hiroshima
    replied
    Question: not sure if you have any experience in building these old motors, but is there a big difference in performance gains between a VC and MA? MAs are scarce over here
    Leave a comment:
  • Hiroshima
    replied
    Thanks Philip. Emailed them; waiting on response
    Leave a comment:
  • philip
    replied
    Originally posted by Hiroshima View Post
    Good day. - anyone know where I can get a Mazda MA/VC/NA engine high performance billet camshaft? I'm in South Africa.
    There is a company here in Australia still making cams for these old girls.
    https://www.waggottcams.com/camshafts
    Leave a comment:
  • Hiroshima
    replied
    Leave a comment:
  • Mick the Mantis
    replied
    I have had experience with all 3 of the engines mentioned- 1600 NA, 1800 VC and the MA 2L. some differences are the height of the cylinder block of the MA compared to the others, may restrict your ability to use factory air cleaner as I found with my 616 when I dropped an MA in there. Engine mounts and sump also need changing. The 1800 VC is the worst of the bunch, it only has 5 bolt crank/Flywheel and runs rougher than the other 2. MA also has round exhaust ports on some models so your VC manifold wont match. MA has much larger front casing and water pump too, one reason why I chose it over the others.
    Leave a comment:
  • loshmee
    replied
    kv77 Thank you so much for this.
    Leave a comment:
  • kv77
    replied
    download link for that, valid for 7 days
    https://we.tl/ETY07PP1mn
    Leave a comment:
  • restoremaz
    replied
    pretty cheap on ebay
    http://www.ebay.com.au/itm/MAZDA-929...AAAOSw4DJYmcMT
    Leave a comment:
  • loshmee
    replied
    Does anyone have a copy of 1.8 VC engine workshop manual?
    Leave a comment:
  • Hiroshima
    replied
    Thanks mate and thanks to all for your input.
    I'll be in touch wrt progress
    Leave a comment:
  • Olycarguy
    replied
    1995-2002 Kia Sportage uses Mazda 2.0L 16v engine. Nearly double the hp of the original VB.  Available in 2wd, the factory transmission works ok but most people use the b2200 bell housing and Miata internals.  I have both set ups and prefer the better shifting Miata box.
    Leave a comment:
  • Olycarguy
    replied
    If I could make a suggestion, go to mazdatrucking.com and look at the swap section. There's a sticky on the Kia Sportage 2.0L (Mazda fe3n 16v) engine swap. Everything you need to get inspired.
    Leave a comment:
  • Hiroshima
    replied
    I must be honest I'm warming to the idea, but I'm not keen on it. Yes the FE3s are freely available over here and you can buy a bellhousing which bolts straight up to a 21R Toyota gearbox, but I so much want to keep things original in the engine bay bar a few performance bumps.
    For me 100 to 110kW is fine; it must be reliable and period correct.
    I also have a complete Mitsubishi 4654 2.6 engine and gearbox, but this will take away from the originality when you open the bonnet.
    I'll let you know what I decide - need to get my head around engine swaps if I decide to do it.
    PS. For some reason I can't upload pics here
    Leave a comment:
  • Olycarguy
    replied
    Are you sure you don't want to convert to a 2.0L fe3n 16 valve?? I'm converting my 1972 Luce to 2.0L fe3n with twin sidedraft 45mm webers instead of fuel injection. I want the engine to look period but be fast enough to trackday with. I bought the intake from an outfit in SA.
    I've modified a lot of the old VB series engines and the port/combustion chamber/ rockerarm design (as well as bottom end design) really limits horsepower. Maximum reliable hp from a naturally aspirated VB-VC-MA series engine is 125-135 tops. Anything more than that and you run into excessive rockerarm wear from modern cam designs. The 2.0L 16v with just bolt ons is close to 180 on pump gas. The earlier comment about the 1600 is correct....... the cylinder head can flow enough in the smaller displacement to at least "feel" like it's fast...
    Leave a comment:
Working...
X
